I tried that Dave and saw no change in the air in the basket. I also read where you could put foam shaving cream on the fittings and watch for where it is sucked in. Did that and did not see anything. I am focusing on one of the unions right now. I took it apart this morning and put some pool lube on the gasket and also lubricated the threads with a water soluble lubricant to see if it would help bottom out the joint when I screwed it together. I put it back together and am waiting an hour before I test it. Not sure it is true, but I read on the web that the pool lube will set up and work better if it is allowed to sit awhile before water is applied.
