Hi
I understand what CYA does but not sure why its required and do not understand fully why I can't maintain pool without it. I have a fairly new pebblecrete (plaster) pool about a year old with a SWG. The reason I am asking is I have a basic drop test pool kit that can only test FC up to 5. Now if I set the recommended levels for CYA to +- 70 then I would need the FC to be higher than 5 and would therefore not be able to test myself and rely on pool shops unless I purchase a better test kit (limited in Australia).
So if I run the SWG for 8 hours during the day (sunlight) and maintain FC at a level lower than 5 but have a lower CYA (0 or even like 30 or so) then can't see how the FC would lower during night (no sunlight). Keeping this routine should be able to maintain the FC as a reasonable level?
Any help showing me what I am missing here would be great.
PH 7.8
FC 2
TA 70
CYA - not sure maybe around 20/30
SALT - not sure around 3000
CH - not sure think around 220
Thanks
PH 7.8
FC 2
TA 70
Thanks
