- Jun 10, 2017
- 10
- Plaster
- Pentair Intellichlor IC-60
I watched white powder buildup on the bottom for the past two years, and finally gave in and vacuumed it out today. I would appreciate some ideas on measures that I can take to prevent more white powder buildup.
A few observations that might be worth reflecting on:
(1) Over the life of this pool, I am constantly fighting high pH. I chalk this up to fill-water chemistry. I add muriatic acid to push down to 7.5'ish, and then in 7-10 days (if we've had no rain) it's back up to 8.0'ish.
(2) I get some scaling on the leading- and trailing-edges of the SWG. It's never been so significant that I bother to ever clean it. Maybe I should be?
(3) When my IC40 failed - I replaced it with an IC60. I did this because my IC40@100% could barely keep up without running the pump for 20-hours in the summer. This powder-accumulation really accelerated once I upgraded to the IC60.
My most recent test results using my test kit:
Thanks!
- FC 5.5
- pH 7.8
- TA 80
- CH 575
- CYA 80
- Salt 2900
- Temp 91F
- CSI 0.27 (calculated by PoolMathApp)
Thanks!
