White flakes in my pool
nickyt
8
Louisiana
Pentair Intellichlor IC-40
Just came back from vacation and I'm seeing a ton of these white flakes in my pool. Its right at a year old, 12k gal, gunite w/ hayward vfd pump, filter, and SWG.
The flakes generally are settling in the corners under my return jets, but I'm not sure if that's because they're being produced by something flaking off in the pump system/piping or if it's just the way my 4 jets point in my rectangular pool to push everything toward the single skimmer.
Flakes are super thin and fall apart/dissolve if I try to pick them up, which makes me think maybe it's something salting up somewhere?
Any advice is welcomed! Can get more pics if it helps. Forgive the dirt. We've been out of town for 5 days and I haven't run the vacuum, which may be allowing these to build up as well as the dirt that's there.
Your last chemistry data in Poolmath is from 19 days ago.
Those likely are from the SWCG. High pH with high TA can create scale in the SWCG.
Reactions: nickyt
