Hi all,
If someone could help me with the steps to fix this and any special cleaning/flushing products to use, it would be greatly appreciated.
I have crazy white Flakes in my snowglobe/hotub. They appeared after I drained and refilled it yesterday and turned the jets on. I did let it sit for a month without checking or doing chemicals. FYI, I did not turn the jets on before I drained it otherwise I would've maybe seen it before. The heater was on and was at 101 degrees. I use Leisure Time for chemicals, spa56, renew, enzyme, defender, bright n clear, calcium booster, spa up, and metal gon for refills. The temp is now set at 99 degrees.
So, I googled it and then tested 8 ounces water with 20 drops of bleach and the flakes are still there, so I assume it is calcium scale deposits and not bio film, but that's a best guess on my part.
I read and searched what to do but did not find clear steps nor what to use to 'flush' the hotub or what to use to flush it. I did some some good steps for someone using bromine on this forum but I'm not sure if the steps are same for a chlorine user.
I also read about using some pipe cleaners. I'm not sure how to figure out the sizes to get and even if they would fit in the holes, so some advice here is welcomed as well.
I also read that water hardness can cause this, but I've always had to add Calcium Booster on every fill up to get it between 25-400, right now it is reading 0 zero because I didn't want to boost it if those are calcium based flakes and I want them to go away. My Alkaline and pH are super low, at 0 zero, because I didn't want to add Spa Up since I read that high alkalinity and pH are a cause of it.
Also, the flakes did settle a lot and I used my manual "Magic Vac" to suck out the settled ones and I did get a surprising amount of them. Now it looks less like a snowglobe and more like a problematic flaky hotub.
I've had this hotub for 12 years running all the time every day, and another for 10 years prior to this and never ran into anything like this before.
