My apologies. I posted this question in this ("SWG selection? Intellichlor IC15 vs Intex") thread a little while ago.
Then I had the notion that maybe I should have started a new topic instead. Thank you for your patience.
_____________________________
Hi, I have searched and found this thread referring to the Intex Saltwater Generators.
I am going to get the intex ultra frame 26' x 52"
I have a G.A.M.E. SandPRO 75 pump (3/4 hp) / sand filter (76lbs of sand)
and I have found this SWG:
http://www.amazon.com/Saltwater-System-Chlorinator-Above-Ground/dp/B000OCZRHU/ref=lh_ni_t
Would someone please advise, is this the SWCG that I need. Due to funds used for all initial start up and pool purchase and tree removal, I will need to start with one of the Intex SWCG's and I am finding that there are several and they look a LOT alike. Some say to use ONLY with an Intex pump/ filter or the flow rate appears awfully low.
This one seems to be what I am looking for. They don't mention copper plates so I would assume this is an older model (the beloved 8110?). Also from what I've read on this forum, this model has a higher chlorine generation rate. Which I believe, also from what I have read, is favorable.
I will be placing my order as soon as I hear from y'all. If you advise "yes" that is.
Thank you,
Thank you,
