My SLAM is complete, and I'm letting the chlorine levels drop. My hardness and alkalinity are a little low. At what point should I work to balance these? Chlorine is down to 9.6 today, so I'm within target but I will try to let it settle between 7 and 8.
Last test results:
FC - 9.6
CC - 0
pH - 7.6
CH - 200
TA - 84
CYA - 84
What order should I tackle this in? Should I pump out some water and get CYA in line, and then re-test and adjust from there?
Thanks in advance to all you smart people out there! I appreciate your advice.
Last test results:
FC - 9.6
CC - 0
pH - 7.6
CH - 200
TA - 84
CYA - 84
