I’m supposed to wait 30 days before putting the dolphin robot in / adding salt.
The pool builder finished the plaster, put water/acid in, let it sit for 5 days, then we turned the pump on and balanced chems. We are at day 22 if you count the day we turned the pump on, or day 27 if you count the day the pool was filled.
Do I use the pump-on day as the 30 day start, or the water fill day?
