when if to culture water
engrav
Platinum Supporter
567
Whidbey Island, WA
Less than two years with a pool but it is in pretty good TFP shape.
If a pool is well circulated, sanitized and balanced, it must be unlikely that there will be harmful organisms in the water.
But is there ever a
1) time when or
2) reason why
one should culture the water?
Searched TFP for "culture" but did not find, nor with google.
Thank you
This has certainly been discussed a lot, but I'll bring it up again - OCLT's are generally not a very good diagnostic tool at Target FC levels.
The OCLT was conceived as a set diagnostic criteria to be checked during a SLAM. Those criteria do not necessarily make sense at Target FC levels.
That being said, failing OCLT at Target FC is probably not a good a sign of pool water health, but passing OCLT may or may not mean anything.
As for culturing your water, that just doesn't make sense for a whole bunch of reasons not least of which is sample control. It's very easy to contaminate a sample prior to spreading it on an agar plate for bacteria/algae growth.
