Just bought my first AG pool (Intex 18x9x52 XTR) and not sure what to put under it. I will install it on the leveled decomposed granite (DG), in Sacramento, CA. The original soil under about 2 inches of DG is mostly hard pan (it's so hard that a small Bobcat could not level it). I was thinking about adding an inch or so of sand to level the gaps and cover the sharp DG pieces, but Intex told me they do not recommend sand. I see mixed recommendations about using (or not using) interlocking mats, foam board, tarp, Gorilla Pad or the likes, and I'm a bit lost. I do not want to spend more than $200 (the less, the better). What would you suggest? If using interlocking mats/foam board/tarp/etc, is there a specific brand (characteristics, like width) I need to look for? I keep trying to get an answer from Intext, but the only thing I was able to get is that they do not recommend sand and do recommend a firm surface (duh!). TIA
