With a CYA of 75, you'd need to drain 60% of your pool to get it down to a CYA of 30.
If you want to start SLAM-ming it right as you start to refill it, I would think you should put "9200" in the gallons column (40% of 23,000 gallons) to figure what your FC level should be to shock. Then keep approximating how many gallons you have in your pool after a half hour or so, test again and re dose according to the new gallonage.
This is an educated guess....not 100% sure that is accurate. But I'd imagine putting in the amount of FC to reach SLAM level for 23,000 gallons when you only have 40% of that might lead to a bleached liner....
