So if I want to skim, I just unhook the hose for the floor vacuum (I don't know the terminology for that device), and it will skim the top of the pool?T,
You can either skim, or you can vacuum, but you can't do both at the same time.
Most old pools have one line connected between the skimmer and the pump.. Without the skimmer hose plugged in to the bottom of the skimmer, the skimmer will function like it should.
Normally, when the skimmer has two pipes at the bottom, one is either plugged, or it is connected to the main drain. If going to the main drain, it means the main drain is not working at all unless there is a floating diverter valve in the skimmer, that floats down and connects the main drain pipe to the pipe that is coming from the pump. You obviously don't have a floating diverter, and for now I would not worry about it.. Main drains are not really needed at all.
One of my next tasks is going to be taking the filter out to inspect and clean it.
