Keep in mind cooking at 211°/225° leaves meat in the danger zone for too long (for me anyway.) Bad things can happen to food from 40° to 140°, cooking at higher temp will push the meat through that zone quicker.
Fancy seeing you here mate. (This is AuzzieMatt)
borjis since all cookers cook differently I would keep the temps closer to 250 and under 300 for sure. Also be sure to get one of these if you don't have one...
Well, I attempted again.
Let me start off by saying the unit I have is a 40 inch Smoke Hollow, incase anyone else has one for reference or further suggestions.
I scaled back from the amount of ribs, down to a single rack.
Instead of baby back, I purchased spare rib, about 6 lbs by label. info.
Did some research on Google machine and decided to trim down to a St Louis style rack, suppose I should have just bought one to start with, threw a lot of meat away after trimming., had no use for it, and did not really try and figure out how to use it, enough challenge with just the ribs, taking last time into account.
I placed a stove thermometer into smoker to compare temp .
After pre heating smoker, temp set to 250 ( on door digital gauge ) , the oven gauge showed 200.
Cranked up setting to 290 deg, which is the highest the smoker goes to.
throughout cooking oven gauge showed 250 deg. and door temp gauge showed 285 -290.
Put a rub over ribs last night and refrigerated.
I cooked for 3 hours at max temp setting, removed and added the mix as a previous post had, with a strip of butter, some apple juice, sweet baby ray BBQ and brown suger wrapped in foil and cooked for 2 hrs.
Removed foil and cooked for 1 hour.
This whole process, I told myself , pay no attention to the smoker readings and just go by time, already planning on throwing straight to the trash, since smoker electronic readings were so far off.
Well, I must say they turned out great.
Maybe not what some might like, but I had to be careful removing from smoker so as not to fall apart.
I guess the other issue I had last time was that I was most likely cooking at a low temp, such as around 175 instead of 225 like gauge showed
