New pool to me and I'm navigating the steep learning curve. I'm getting a pretty firm grasp as to what everything is and how it all works, but I do have one question. We have a 2 pump system to accommodate for our in floor cleaning system and 4 skimmers.
Pump 1...aka Pool Pump, "sucks" water from 4 sources: 3 of the skimmers and the canister filter by the pool which I'm pretty sure draws water from the main drain in the floor. Return water for this pump goes to wall mounted down jets and also 2 fixed floor jets that shoot water in the direction of the main drain.
Pump 2...aka Cleaner Pump, sucks water from 2 sources: the Fourth skimmer and also the the main drain, but bypasses the canister filter. Return water for this pump goes to the in floor jet system.
There are 3 wall mounted circles I"m trying to sort out what they are. Please view the 2 photos below:
Red circle is at the bottom of the pool in the deepest portion. As far as I'm aware, this is the "main drain". Both pumps "suck" water from here. Pool pump sucks the water from here via the canister filter and the Cleaner Pump sucks water from here directly (no inline filter). As far as I'm aware, the green circle is a secondary to the main drain. The suction from the main drain also has suction here. This is to prevent a child from getting sucked and stuck onto the main drain.
On a different wall, I have the 2 yellow circled wall mounted disks. They are identical and on a different wall from the green circle disk. What are these yellow circled disks???
Ultimately why I'm going down this rabbit hole is I'm trying to troubleshoot my infloor cleaning system......I just have super low suction in my main floor drain. I can nudge a leave within an inch of the drain and doesn't even get sucked into the drain. I'm beginning to wonder if Both yellow And the Green wall mounted disks are sharing suction with the floor drain (not just the green one) and as such the shared suction is split to many ways to result in proper Red Drain suction.
Maybe I'm completely off altogether on this. Hoping someone can steer me in the right direction.
