Who did you use to do your Primera Stone? How is it holding up now in 2023? Thanks.I had Primera Stone applied over 3 yrs ago. My smoothness is opposite of what you describe. I have maybe 2 or 3 rough areas. Mainly on a vertical wall. They are no larger than 6 inches diameter. I found these months after it was done and felt it was just minor defect due to manual polishing of the finish. On the second day they had a crew of 3-4 with hydraulic sanders hand polishing it. I think you should call your PB to come back out and feel the finish that you describe. With handcrafted finish there will always be some imperfections but yours seem to be extreme.
Moved from here.
