Hello all, I'm trying to diagnose a weird issue I have with my spa losing prime. Been this way since ive owned the pool (3 years).
Pool primes and keeps prime indefinitely with pump off
Pool & Spa primes and keeps prime indefinitely with pump off
When turning off pool suction while both are running and primed, after about ten seconds air begins to enter the pump, and within a minute there is a massive air bubble, regardless of pump rpm. Spa has a single drain at the bottom.
Could this be because the drain is only 4 feet underground and the ~700 gallons of weight doesn't "push" enough water through the spa suction drain? Could this be because of an air leak, even though it holds prime?
