I realize that many tests have some variation, but when comparing results, especially when looking for trends, reducing some of that variability would be a good thing. Reading sample volume by eye is one source of variability. I have a small pocket scale (200 gm, 0.01 gm readout) that I use to measure the sample. The specific gravity of pool water is very close to 1.00 so mL water is very close to grams water. The procedure is simple: rinse the sample tube with the pool water; dry the tube with a paper towel; put the dry tube on the scale; hit the tare button to zero the scale; then fill the tube to the desired amount (I use an eyedropper for fine adjustments.)
