b,
Spillover spas operate when in the pool mode. Most of the water should go back to the pool, but some of the water is also sent to the spa to cause it to spillover into the pool. Any decrease in the water flow will cause the spa overflow to get weak.
Normally this means that the filter is dirty, and that could be the case, but due to our recent weather, I would be looking for something in the return line that is still frozen.. Could be inside the filter, causing weak flow..
If one of your valves on the return side is partially closed, this could also decrease the flow to the spa. But.. there can be a number of valves on the return side, so no way to know which valve you are talking about without some pics.
