- Apr 19, 2016
- 171
- Plaster
- CircuPool RJ-45 Plus
Waterway Booster Pump 3/4 HP for Polaris -> replacement parts?
Good evening...so I went outside tonight to do my normal maintenance on my pool, and BAM, the pool level is down like 6 inches! NOT GOOD! So I ran to the filter and water was spewing all over. Ends up the cover (front) of my booster pump is cracked and leaking. So I quick turned it off, settled down. Not sure how long was doing this, but enough to make my water bill have empty my wallet! So I started putting water back in pool, and then disconnected the hoses on my booster pump to bypass, so I can at least keep the filter going.
So, my question is...the motor still works. Can I replace the front part? Not sure what you call it, the impeller? casing? Anyway, a whole new unit is like $200. I was hoping I can just replace the busted part. I searched online and can't find anything. Anyone have any ideas?
thanks!
Paul
And one more thing....Is is a 3/4 HP, model 38104301PDA. If I need to buy a new one, stick with this? Or is there a better one out there?
thanks!
Paul
