I’m a CPO & have a new client who’s dealing with some issues & I can’t seem to figure it out for the life of me.
Pretty much His waterfall works when it wants to. His pool pump is fully primed, no air in filter but seems to drop pressure after a hour or so while his pump is still full to top. But that’s not what I’m only confused about,
When we first start the system up his jets work great but once we open the valve to the water fall there’s no flow, jets will still work though.
We have to turn the system on with the valve open to even see a tiny bit & like I said sometimes it’s a lot better then usual but not at all what it used to be from the previous years.
I doubt it’s a cracked line, seems to be more of a pressure or air leak issue however I checked & couldn’t find anything. Very stumped any pointers?
All the lines seem fine besides one return to the pool that you can see constant air bubbles come out of
