Always possible an animal could do it, or bbgun/airsoft pellets from kids. See any small plastic pellets the size of a pea laying around? The second picture makes it look like something small went through one side and out the other.A couple of weeks after I filled new tubes, half of them were shredded. All of the shredded ones were on the same side of the pool. The weather's been mild. Should I blame the manufacturer or would some kind of animal do this?
View attachment 535782View attachment 535783
Nope, no kids around our backyard. It was actually shredded, with pieces scattered nearby.Always possible an animal could do it, or bbgun/airsoft pellets from kids. See any small plastic pellets the size of a pea laying around? The second picture makes it look like something small went through one side and out the other.
I'm starting to suspect one of the neighbor's many cats. The solution, I think, would be to wrap the tarp over the tubes, like a burrito, assuming there's enough extra tarp. That would also block UV damage. Maybe. It's all a big maybe.Sounds like an animal clawing at it. Any manufacturer defect would not scatter pieces around.
I recently had a ground hog burrow under a retaining wall and claw through thick irrigation control wire that was where he dug. A pest control specialist set traps by the hole, captured the ground hog, and relocated him a few miles away.
They sell hard plastic water “tubs” that I use. Those have other issues too.I'm starting to suspect one of the neighbor's many cats. The solution, I think, would be to wrap the tarp over the tubes, like a burrito, assuming there's enough extra tarp. That would also block UV damage. Maybe. It's all a big maybe.
