Water loss
IL_WS
132
IL, NW of Chicago
Had a slow leak last year that I neglected to find the source of. At closing I let it drop to see how low it would go. It appeared to stop at the inlet. I had replaced the grommets at the start of last season thinking that might be the cause. Plumbing has some slow drips that maybe I underestimated?
Not sure on next step for this season. Replace inlet grommets again. Replace skimmer grommets. Liner (and pool) is about 13 years old.
By grommets you mean gaskets?
You use the correct gaskets?
Try replacing them again. Did you overtigthen? Gaskets are like O rings and overtighening deforms the gasket and breaks the seal.
