I have a small reservoir on one side of the pool that contains a float and the water input that fills the pool. When the level gets to low -> the float sinks and opens the valve -> water flows and fills the pool. When the level rises the float rises and closes the valve. The problem is…. The float is getting filled with water and sticking. I've come home a handful of times now seen water pooring into the street. come to find the float is submerged and I have to pull it up. I've tried using plumbers tape to try and seal it, and was thinking of pulling it back off and using silicon to seal it. Or I guess I could go back to LPS and get another one. Has anybody else had this problem?
