Even when I turn the diverted to spa only water goes to pool returns. I have replaced the diverted paddle and the check valve to no avail. I want to be able to heat just the spa and circulate the water from the spa only during the winters.
The spa return line has a valveless leg as pictured…could that send water to the pool return for some reason? When I’m in this arrangement the spa drains as the return pressure is less that the amount being sent to the filter.
