Hey All,
I’m a bit confused about water chemistry for our spa which is attached to the pool (currently closed for the winter). I’ve read the sticky by Nitro and I’m not sure if it applies to what we have especially when it comes to the suggested CH level.
![](http://i1376.photobucket.com/albums/ah6/chieftoymaker/IMG_2995_zpslpnrjaef.jpg)
I have been balancing the water similar to how our pool is maintained except I keep the TA around 60ppm to help offset the quick rise in pH. Now I’ve read that TA should be kept around 50. But, 50 and even 60, isn’t in the recommended range on PoolMath . If I change TA to 70, I’m adding in muriatic acid every 3 days or so.
Should I forget what’s recommended by PoolMath? Go with the spa setting instead of a tradition pool setting? If I did go with the spa setting, wouldn’t the low CH have an effect on the plaster?
Latest numbers are:
FC - 7.5
CC - .5
pH – 7.6
CH – 310
TA – 60
CYA – 40
Borates – 0 (will be adding in once I figure out what ideal numbers are)
Currently, I have the SWCG winterized and manually chlorinating with bleach (too difficult to dial in a perfect setting with the fluctuating temps) . Min. and max. temps are between 72 and 100. Sitting in the corner of the equipment shed is a big ol bucket of boric acid ready to be added (not all) once I get the numbers straightened out.
Suggestions/Recommendations? Anything would be greatly appreciated. Thanks!
Latest numbers are:
FC - 7.5
CC - .5
pH – 7.6
CH – 310
TA – 60
CYA – 40
