In addition to what Jason said, Vacuuming is important if you can't see the bottom but aren't sure it's clean.
You should vacuum till you're absolutely sure there's nothing down there.
If you're clogging your filter when you vacuum, there's a lot down there and you need to keep at it till you can vacuum and get nothing out of it.
Yes it takes a lot of time and patience to vacuum when you can't see the bottom, but that's when you really need it the most.
As for your R-0871 lasting a season or more. That's correct unless you have to shock, then you use it up pretty fast.
Getting more isn't a problem. Go to http://www.tftestkits.net/ and they'll ship it to you quickly.
