- Jul 29, 2017
- 215
- Plaster
- Pentair Intellichlor IC-40
A number of years ago I had a Loop Loc cover installed. Polystyrene wall foam was used as a padding around the coping. I have been able to reuse that foam each year but it is starting to disintegrate and needs to be replaced.
I went back to the company that installed the cover and was able to buy a 120' roll, but the width is 42". The installers cut that in half to a 21" width to use it but I was not present to see how that was done. I know I can unroll it and use heavy duty scissors to cut but it would be easier to do while it is rolled up.
I am sure a cross cut saw is not going to produce a clean cut. Does anyone know what can be used to cut it while rolled up? I don't want to ruin it experimenting.
