Hey all. I just bought a Pentair Intelliflo3 VSF to replace my Hayward Northstar. After removing the Northstar it appears that the intake line doesn't match up. That being the case should I just shim up the pump with a piece of pressure treated lumber, or cut the lines and lower them? I have attached images so you can see the difference.
Also if I have to cut and lower the lines for the Skimmers, Spa drain, and Main drain. Will the water pressure force water out of the lines impeding me from being able glue on couplings? Thanks
