I have an in-ground vinyl liner pool. This is my third year opening it. I typically lower the water level to a few inches below the skimmer box which also means my top step in the pool is dry all winter. I've noticed that the vinyl on that step is starting to shrink a bit. I assume this is normal for the plastic but is it something I should be concerned about? The liner is still in place in the coping but there isn't enough of it to sit flat on the step. I'm hoping that with the weight of the water when its back to normal levels and the heat will help it ease back into place. Anyone have experience with this?
Thanks!
Thanks!
