Vinyl pool leak
Jmag34
7
US
Hi all- New vinyl pool owner with a leak as of a few days ago. The leak occurs during day and at night with pump off. Have not been unable to locate any issues with the vinyl yet but I just saw water coming up from the ground where light junction box is (looked like water boiling/simmering on a stove top) is that a definite sign that the light inside the pool is the source of the leak or more complicated than that?
Thank you!
Bubbling/Simmering water from the ground doesn't sound normal (unless you live near Yellowstone ☺️), but I think you're probably on the right path. Aside from seeing the water bubbling, how do you know you have a leak? Did you happen to do a bucket test?
If you could post photos of the light junction box it might help diagnose what your issue is. Alternatively, you said you're a new vinyl pool owner, so if this is a new new pool then I'd just make the pool builder aware of the issue and they should remedy it.
To clarify, I recently moved in so I am the new owner :) The pool is not new although the liner was replaced 2-3 years ago. yes did a bucket leak test.
Here is a photo. you can see some of the standing water but the "bubbling" is right around the pipes but without video hard to see (I assume I cant post a video here, right?)
Ah, so it's not a new new pool, but a regular new pool ;).
Since you say have a leak with and without the pump on, it is probably not in your suction side plumbing. If you wanted to verify, you could plug any returns and skimmers/drains to verify that. I think your intuition that you have an issue with a light seems reasonable to me, but unfortunately I don't have any lights in my pool so I don't have the slightest idea where/how one might be leaking.
Let's ping @Texas Splash and see if he has any ideas.
Reactions: Jmag34
Well, maybe. We know that with conventional lighting (lightfixture in a niche), water can flow through the conduit all the way back to the J-Box. That is why the J-Box has to be a certain height above the pool's waterline. Normally if there is a break in that conduit it happens back at the pool. I guess it could happen closer to the pad. Do you have a standard (large) halogen light in a niche, or do you have the nicheless 3.5" LED lights?
In your notes above, I only saw where you seem to be losing water with the pump off, is that correct?
1) Niche: Not positive but here is a photo. My guess would be conventional
2) Losing water 24/7- with pump on during the day and pump off at night
3) To confirm placement, the J-box is 15 feet behind the light fixture. The pad is 25 feet from the J-Box
