You need to get mean and kill that algae for once and for all.
Just for demonstration, because I have no idea of the exact numbers, let's say algae doubles every 24 hours. And let's say it isn't visible until you have 3 million of them.
So you brush and chlorinate and kill the huge majority of the algae and you have only the faintest traces left, lurking behind a light or inside the ladder. Hardly any. Maybe 2,000 spores. That's nowhere near the 3 million you need to even see the stuff. And tomorrow you have 4,000. Then 8,000. Then 16,000, 32,000, 64,000, 128,000, 256,000, and boom, now you see if because all-of-the-sudden, you have 512.000 spores. And you get busy with the bleach and the brush but this time you stop with 100,000 left. And in just a couple days, algae again. So what you need to do is kill it all. That means hit it again and again and again. Never let it have the time to reproduce. That's called a
SLAM Process Shock Level And Maintain. The M is the critical part. Too many people think a one-time megadose of chlorine will do it. It doesn't. The high chlorine levels have to be Maintained.
Algaecide works better as a preventative than as a cure in the same way that cleaning surfaces with Lysol stops the spread of colds but drinking it won't cure one.
