So I’m guessing there is a hole in my pool cover and the water is VERY DIRTY. Usually it’s crystal clear. What’s best? Let the filters do their thing? Or start with new water?
As you have a vinyl pool liner you can drain to no more than to within 18" of the shallow end. So I would suspect it is best to filter out if it is just solids.
Can you post a full set of test results?
