Hi Everyone, and THANKS for the great education and help over the past 10 years.
As in Sig, about 20,000 gallon pool, On/In ground. Ice just finished melting Pool was drawn down about 30% to below returns, Covered (but cover was partly off this Spring.)
Just refilled (good well water) and quickly added 2 GAL of 6% to get FC to about 10. Water temp about 45F Water very clear.
What next?
- External siphon vacuum cleaning leaves / leave residue from bottom. Almost done.
- Soon to restart pump. Need to close drain on sand filter.
Questions:
- Residual CYA: Was 50ppm at shutdown before Winter-over and 30% dilution. IsThere any expected residual? Cheap test says about zero.
- Residual Borate: Should I expect any or just start as if there was zero?
- Should I keep the FC up about 10 for a while?
- Should I let FC be lower before I start adding CYA?
Any suggestions of sequence etc appreciated...
Not going to be IN the pool myself for a bit
What next?
Questions:
