Variable speed pump 115v?
Kiddo44pct
Active member
Apr 20, 2017
33
Nyc
My regular pool pump seized looking to get a new one. Can anyone recommend a 115v variable speed pool pump. Most are 230v but I don't want to change my electrical
Also my pool setup is Aquasport in ground 15x24 that is 54 inches deep. Thanks in advance..
The pump below is a good option and is 115V. Can you fill out your signature with specific makes and models of your equipment? Important to balance the pump with the capabilities of the filter.
I added all into my signature..
Any other options in 115v?
Was hoping to be under $1,000..thanks
Reactions: PoolStored
is the CC150 to small for a SuperFlo?
I would use 0.375 gpm/sqft as the maximum.
That is 56.25 gpm maximum, which is more than you should ever need.
You probably won't ever need more than 15 to 20 gpm unless you have a heater.
I have a small heat pump attached
