Recently during the freezes in Austin, I could hear my pool pump occasionally make a real racket. I discovered this was because the freeze protection was switching between pool and spa mode a couple of times an hour, and the instead of the valve handles rotating 180 degrees, they just went all the way around. At various points, the inflow was apparently cut off and the pump made a racket and the pipes shook. After three or four of these cycles, the valves would finally stop rotating and all was well until the next pool/spa switch. Nothing seems to be damaged and now that the freezes are over, everything seems ok.
The valves say "JVA2440 Maximum Torque" on them and the handles say "never lube" -- it's all Jandy equipment so I assume these are Jandy valves, installed in 2006. Photo attached. Pool builder out of business, of course.
Today, I put the system into service mode and pressed the "pool mode" and "spa mode" buttons several times to see what the valves would do. The first two switches were fine -- they went to where they were supposed to. On the third try, the outgoing water valve went all the way around three times before settling in at the correct location.
I found a YouTube video describing how to take the cover off the valve actuator and adjust some kind of plastic thingies, but it was unclear what was being done (not a great video). Are these valves ever supposed to go all the way around? Each valve sits on top of three pipes.
Might this be a problem with the electronics instead of the valve actuators -- that is, do the Jandy electronics in the control panel tell the valves how far to turn? Should they ever turn all the way around or is there a mechanical stop in the valve?
Thanks in advance
Thanks in advance
