From doing some research on older threads here about cleaning DE grids, it has been suggested a few places to soak them in detergent. I use a large bucket that accommodates my entire grid assy but have only ever used the pool store "filter cleaner". Is using a dishwash detergent mixture better? I just assumed that whatever 'acid' is in the filter cleaner solution would degrease and whatever else to effectively "clean" them.
Today I installed a set of new grids and, in looking at the old ones (well, actually only two years old!), once taken all part from the pastic rings that go in between each of the 10 grids, what always LOOKED clean after a thorough hose-spraying following each backwash turns out to not look clean at all. There's no way to really see what they look like unless truly taking apart the whole assy. So if anyone has a suggestion on how much dishwash detergent to use, that'd be worth a try. I perhaps am diluting the filter cleaner too much since the bucket is really quite large, but I only fill it half-way with the water/cleaner mix, and then after 12 hours of the one half of the grids soaking, I flip it and give the other half another 12 hours. It may VERY well be that the newer grids simply aren't made as well / durable as older ones. Now wouldn't THAT come as a real shocker LOL
So here are the new ones......the DE dominoes game.....FUN!!! I cleaned all those plastic spacers real well too - there was gunk in between the slats that are in each of those. Those individual compartments I'm referring to don't pass through, but still...figured can't hurt. Hardest part is finding the threaded piece when passing the rod all the way through the assembled grids. This thing can fall apart VERY easily before it's all tightened up. Easier with two people. These grids are also getting harder to find, being that they were for the old Anthony Apollo VA-52 filter. Thing is built like a tank - NO plastic parts anywhere - all stainless steel. Have never even had to replace the clamping ring that holds the two parts of the tank together.
