mas985 said:That's nonsense. The valve will fill up with very little flow rate. Besides, the multi-port valve does not fill up with air when the pump is shut off anyway. At least it shouldn't so it is always filled with water. But you have to ask, so what if the valve doesn't fill with water? What difference would that possibly make? The important thing is to flush the dirt from the sand. His comments just don't make any sense. I think he is making it up.
My thoughts exactly Mark.
I just placed another call to Pentair to find out what happened to this supposed "spec sheet" he got these claims from. He says he got it out of their catalog, but it's nowhere to be found in there.
The rep I just spoke to, Gayle IIRC, says I need to talk to Carl Popma in WI. He's their nerd apparently.
She did confirm that it only comes /w a 2" multiport, so that blows holes in what he said right there.
You do know we shouldn't ask such silly questions of.... well, you know.
You might not like the answer after all. LOL
My favorite here thus far is...
*Places head in hands, beats forehead repeatedly.*pool store & local pool service says.. said:"DE in a sand filter will ruin it" .... "Sand has to be changed every 2-5yrs cause it rolls around just like in the ocean."
UPDATE:
I just spoke /w Carl Popma @ Pentair. He confirmed, as you have said, that maximum flow of a sand filter is 20GPM/SQ ft. to avoid channeling, recommended flow is 15GPM/SQ ft. and minimum is 10GPM/SQ ft. He confirmed that any old flow rate, even a trickle will do for just daily filtration, but for backwashing, in order to achieve proper disturbance and agitation (I think he used that word) of the sand bed so it'll clean properly, you should target to the middle @ 15GPM. Which for this filter /w 4.9SQ ft. of surface area would be 75GPM. The low end @ 10GPM would equal 50GPM minimum backwash flow rate. He said if you can only do the minimum, it'll still work, it'll likely just require longer backwash times in order to get it all clean.
Does that sound about right?
Head loss & required pump..
Apparently the headloss of the filter, which I forgot to confirm /w Carl, is 37ft/head.
What is typical headloss of the usual AGP 1-1/2" hose setup? 10ft, 20ft... more?
Best case scenario, at 47-50ft of head on a Pentair Dynamo 1.5HP stock, I'm looking at 15-20GPM flow rate. YIKES!!!! That's a weeny pump.
The Hayward Power-Flo Matrix isn't much better @ 27GMP for 50ft/head.
I see that the highly recommended Pentair Whisperflo 2-speed @ 3/4HP will yield 70GPM @ 50ft of head, or 60GPM @ 60ft of head. That ain't bad.
But what's bad is it's almost a $600 pump, even after deal hunting, 2x the $$ of the Hayward.
Using the Dynamo as a booster pump?
Can I just plumb in 2 pumps?
IE. Buy a new Hayward Matrix for about $230 bones (found me a deal), then plumb it alongside the Pentair Dynamo that comes /w the pool. Then only run the Hayward on low for daily filtration, then when it's time to backwash, kick on both pumps at full speed.
Will this work?
Or will I get even more headloss from this setup?
Even considering that the filter has a 2" MP valve union, allowing both of these 1.5" pumps to merge into a 2" pipe via a step up at the pump head. It's probably incremental, but hey, an idea.
