UPDATE HELP PLEASE: FC dropping during hot days! Bad cell or normal?
When you say your pump was running all night - was that with SWG or without? In order to the OCLT, you will need to have the SWG off. When I test my water, I just make sure water is circulating about 30 minutes before and certainly at least that or more if I do add anything to the pool. How old is your IC40? Regarding your question about if the IC-60 will fit, I am not sure if the dimensions are any different but the folks at INYOPOOLS.COM would be able to assist and if you become a Gold Supporter, you can get a good discount if you decide to purchase one.
Last night FC was 9-9.5, this morning without pump running FC is 8-8.5. I am waiting on pump to run for 30 minutes and going to check FC again. Looks as if I dropped .5-1 overnight.
Normal?
Will report back after pumps runs a little and I check it again.
