It is difficult to SLAM when you have no patience! I started on Monday 5/29 with a rinky dink test kit & the color of the pool water has gone from deep dark green to just green but super cloudy looking. I bit the bullet and purchased the fancy smancy Taylor K-2006 kit for water chemistry. Here are my levels:
FC 4.5
CC 2
PH 7
CYA 38ish (between 30 & 40 but over half way)
Alkalinity 90
Pool Math app suggested adding 2 gallons of 10% liquid chlorine, I put that much in this morning and when tested on the rinky dink test kit, the color is the same now as it was then (tested just now after taylor kit for giggles/comparison to see if there was much change throughout the day.) There was not, so am I actaully getting to shock levels? I THINK my #s are okay to SLAM with but not seeing my pool change much should I test free chlorine after I add to chlorine to see? What about combined chlorine, how do I get that to 0? And I have NO patience! UGH! Thanks in advance for any help!
Oh & yes, I am brushing walls and floor & running robot to get out any leftover debris but it is coming out pretty empty, but definitely stirs stuff up.
FC 4.5
CC 2
PH 7
Alkalinity 90
