So I just bought a home that has a 300 gallon spa and a 20000 gallon pool. Pool needed a new liner upon opening so I started fresh there and decided to drain hot tub and start fresh there as well. Started out by going to pool shop that did liner but started asking questions when I was getting readings of 0 alkalinity with high pH... so I've been doing research and essentially have a few basic questions. As far as the spa goes... all I need to do is add bleach according to the pool calc correct? I don't need to be adding water trends spa shock or Sani chlor? Pool place is telling me to add sanichlor once a week and spa shock every time I use spa. Ive realized that sanichlor has stabilizer in it and my readings are currently off the charts of my test strips (I have a proper test kit that will arrive Monday). For the pool... my CYA level is approximately 90, and fcl is 3.... after reading this website I need to drastically raise fcl or drain part of pool and replace with fresh? Once I get my numbers in balance and finish off this $200 25# bucket of chlorine I was sold...I should be able to just use calculator and add regular liquid bleach to maintain my fcl levels correct? Also how often should I be using a non chlorine shock in both spa and pool? Thank you all for any help and I apologize for the multiple questions and run on thoughts...
