I already have this timer Intermatic-PF1112T, will this support a two speed pump like Pentair SuperFlo . How I will configure my two speed pump to go to low speed (1725 RPM) after say 10 minutes of initial start?
Most people leave the pump on low speed by default, and then have a manual switch to turn it up to high speed when they need that. There are some advantages to starting on high speed with a DE filter. That can't be done with a single timer. You would need to get a secondary timer to control the speed selection.
Thanks Jason, I am not sure about cost and complexity involved in adding a secondary timer, it seems I need to invest in a VS pump like this Hayward MaxFlo, based on mas985 excel sheet MaxFlo is my next efficient in line.
Are you skilled with making electronic gadgets, or maybe you know someone who is?
I can think of one way without a microcontroller that would allow you to start your pump on high, then after a set time would drop it to your lower speed.
Look around your area, I think there is a hackerspace/makerspace where creative people go to make things they want and need for personal use.
I have zero experience in making electronic gadgets, that place is only 10 minutes from my work, I am leaning heavily towards MaxFlo, in that way I can use the existing timer(on and off) and the pump has the timer to switch to low speed, yes MaxFlo is $200 more than 2 speed pump but I see that might be cleaner option. Thanks for the suggestion though.
