Two goals at once?
Pepperdinegal
158
Las Vegas, NV
CircuPool RJ-60
Good morning! I have two goals that I’d like to achieve and am wondering if I can do them at once or if they would compete with each other. My TA is currently 130-140 and I’d like to get that down to 70/80 so I’m going to use MA to drop the pH to 7.2 every time it hits 8.0 (which seems to be every 3-4 days).
Also, I’d like to raise my CYA from the current 40 up to around 70 using dry stabilizer in a sock.
Can I do both at once without compromising the other?
Dry stabilizer will help you lower your pH...For you, adding 8lbs of dry stabilizer will get you from 30 to 60 while dropping your pH by 0.6 (note that you may never see this full drop because the stabilizer doesn't dissolve instantly like MA would).
