We opened our pool for the season on 4/13/2024 (just over 3 weeks ago). It took a few days to clean/vacuum/filter out the silt and get the water chemistry back in balance. On first use of the spa, we noticed the plaster felt rough (I posted about this in a separate thread). I haven't had a chance to do much more research into the rough plaster issue or really "do" anything, other than I've been trying to keep the pH from getting too high.
After using the spa with no problems several times, we noticed one day last week that the spa wasn't heating past 96 or 97 (set to heat to 100 or 101). This was the day after a thunderstorm which caused a brief power outage and made the pool lights come on for a minute or two (lights turned off by themselves). We have since lost connection to the heater from the OmniLogic app and can't seem to get that connection back.
I've been able to test the heater by running it manually using the heater's touch screen. I've verified that the max "lock out" temp is set to 104 for the spa and 90 for the pool. I've powered-down everything and left the power off for a good 15-20 minutes in hopes of re-establishing a connection with the OmniLogic, but that did not work.
In the meantime, we're having these problems:
(1) There is a bunch of this turquoise and rust-colored "grit" settling on the spa benches (mostly, but there is also a tiny bit settling on the pool entry steps). I vacuumed it up with a stick vac so I could take pictures. Using a magnet, a little bit of it does stick, so there must be something metallic in it. Putting some acic on it, there is no bubbling. The acid turns whatever it is a dark yellow, and as the stuff dissolves, the color turns a very dark blue/green color, almost black.
(2) We're hearing a rattling sound that seems to be within the housing of the blower. We almost never use the blower, but turned it on a few times to make sure it's working (and it is).
What do you all suggest we do to troubleshoot?
