Hello Folks,
I'm trying to track down a problem with reduced pressure at the pool returns. I noticed it about two weeks ago, and it seems to be getting worse. My cheesy little plastic fountain feature used to spray water about six inches into the air and now it is down to a dribble. I have also noticed a continuous flow of small (about 1/4") air bubbles coming out of the other three returns. I can't find any air leaks on the suction side (checked the pump basket lid and it is secure and leak-free, no unions that could leak, and all other connections seem secure) and there is no unusual air bubble accumulation at the pump sight glass. The only difference I can document is that my normal filter pressure is 18lbs, and lately it has crept up to 20 lbs.
I do have a long-abandoned water conditioning system cartridge ("Fiberstars Catalyst") mounted inline between the pump and the filter. Apparently it required period recharging (removing & refilling) but I'll bet it hasn't been touched in over twenty years. Another source online (can't remember who) said that as part of it conditioning process it introduced air bubbles into the return stream.
Questions:
Could the slight increase in filter pressure be connected to my reduced return pressure? If not, where to look next?
Should I remove the catalyst? Can anyone confirm that it is supposed to put air bubbles into the return stream? I figured it may be inert but now I am wondering if it may be doing any harm.
Thanks in advance for your assistance and support.
Questions:
