Ok, I have had issues with COM errors with an intellichlor in the past and Pentair was kind enough to send me a new motherboard, so I have swapped them back and forth a few times and am stumped and need help trouble shooting.
I cleaned the contacts to the intellichlor daughter board, so that now is communicating with the ET and will respond to 1% changes on the ET, rather than the 20% changes on the intelliclor's faceplate....cool.
so problem 1) I Cannot get my solar valve to operate. I have flipped the polarity switch, tried manually using the solar button in service mode, tried a different actuator, ensured there was enough of a temperature differential, and that solar is selected as heat source, and enabled.
Its highly unlikely its the ET hardware since I have a new one and both yield the same result. I guess I need a way to test the actuator. can I use a 12v battery (even though its 24V?)
problem 2) if this should be a separate post, please tell me MODs. (but perhaps this is all tied together?) Intelliflo is not communicating. I have a 2nd cable and tried it. same result. switched motherboard. same result. the original MB allows me to get into the intelliflo menu, but when I hit status, it says no comm. the new MB won't let me choose which type of intelliflo...likely the newer firmware locks me out because it doesn't sense the intelliflo. I have found the slightest of drips on a union which is above the pump..so its possible that some amount of salt water has migrated and done damage, or at least corrosion. I tried some NoOx on the contacts, no change. So how far would I need to pull the drive unit apart to look at the connector or electronic bits to see if there is corrosion. I have the VS version, last digits xxxx18. it should simply be plug and play, once communication is established, the ET takes control and the local panel on the pump goes out, correct? (I believe there are other versions that require some button pushing on the pump controls)
screenlogic 2 is not communicating. my pc auto updated to WIN10, but it appears Pentair does support this. after depressing the reset on the brick I was able to see it, and update it to 733 firmware. I uninstalled screen logic and installed the latest on their site. I get to the opening screen, and I can see the 6 digit brick ID listed, but then...nothing. SL2 won't launch. Any words of wisdom?
the system all ran great, with the exception of communication with the intellichlor, but that is now the only thing that is working! Well, I can still activate my lights by selecting aux1
