Hi,
Over the years, I've noticed my plaster pool getting larger and larger stains. I believe part of the issue is that I don't really do much during winter time. It's cold enough that algae don't tend to grow very quickly and I'm assuming that the lack of brushing once a week has made it such that the little bit of algae that was in there ended up staining the concrete. Regardless, I've tried to shock my pool and brushed the walls heavily but it's not going away. I've tried to drop some cal hypo at the bottom and leave it overnight and that actually helped to clean/bleach the stains that were below the granules (which is why I believe these stains are organic). The problem however is that there's some nasty stains on the walls and I can't exactly leave granules on the wall. Again, I've tried to scrub with a brush aggressively and I also tried to scrub the stains with a 3" puck but that didn't work. Interestingly enough, the stains tend to start about 1' from the waterline and they go all the way down until the floor shows up. The heaviest stains tend to be in the part of the pool that's shaded. What could I do to address the stains?
