Just switched from Goldline AquaPlus to OmniLogic PL using the Tristar SP32900VSP filter pump. The controller finds the HUA, but when I go to start the pump, it kicks on and then almost immediately shuts down. Only after resetting breaker can I turn the pump back on only for it to shut back down.
Once it kicks off, I get the following error: MSP_DEV_COMM_LOSS,Comm Loss Device: xx-xx-xx-xx-xx HUA:VSP.
Back story, on the Goldline AquaPlus system, we had a freeze in South-East Texas and both Aux 1 (waterfall pump) and Filter Pump were running in freeze protect mode. Randomly the aux 1 pump kept shutting down and starting back up. Then as time progressed the display board said comm error. I reset everything and then the controller started resetting itself and would not stay on for more than a few seconds. I then shut everything down, drained the pool equipment and waited for the freeze to pass. Started back up and controller was doing same thing. Took this opportunity to upgrade to the OmniLogic PL.
Anyone have this happen to them or know the potential cause? I have a technician coming out tomorrow, so hopefully I can get some resolution as i have been dealing with this for >1 week now.
