I purchased
Hayward W3SP3206VSP TriStar VS Variable-Speed Pool Pump, 2.7 HP
And I’m trying to connect it to the
Jandy Aqualink RS8
I understand that they are not compatible with the low voltage wiring. So I followed the instructions for the relay installation method. I dedicated 4 relays - 1) is the 220 input to turn the pump on and off. 3) is to control the variable speed. I used the COM as a power supply as instructed in the Hayward manual. I know my jandy relays are operating correctly. I tested my relays and they are working correctly. And I set the pump on external relay control on the Hayward interface.
After the pump is priming the relay still does change the speed of the pump.
I have spent several hrs with haywArd technical support and I’m yet to find a knowledgeable person. Please help!
Jandy Aqualink RS8
