Hi guys,
I've had a spa for a year now beachcomber 340. using liquid chlorine at first. but had an issue with PH rise all the time even with lower TA. over the winter with reduced use. I got tired of adding chlorine every day so I used the trichlor pucks the spa came with. been using them since the last drain and fill middle of Jan. Now I realized my CYA is way too high over 100 probably 120. now according to the charts I should be adding more pucks to raise the FC but that will just make the CYA worse.
I use a floater and only put one puck in at a time. one puck lasts about 4 days in the floater and then I coast for a few days to let the FC drop a little before adding another puck
I know this is bad but my problem is that the spa has never been so nice. I rarely have to add acid. the water smells nice all the time. with liquid chlorine we sometimes get a waft of unpleasant odours. My CSI index is not too far off target.
we have been using the awesome purge at both first and second fills the only one we skipped was the one in January that was just a drain and fill as fast as possible.
I'm wondering if the fact that we use the spa less often in the winter is partly to blame for the water being "Nicer"
I'm thinking of switching to a saltron mini but kind of worried about the heater crapping out in the middle of winter.
