Alright so after watching water chemistry 101 on YouTube posted by HTU I figured I would try the technique. Trichlor is rather acidic but if you keep your alkaline in the 120s things should work out pretty good. So what I did was used my old spa frog silver floater cartridge and used a drill to hollow down a chlorox 3” true blue Trichlor tablet to insert into the floater. I keep the dial release gauge completely closed and normally have a chlorine level of 1-2ppm. Curious if any others have tried this but so far HTU is spot on with the video of how this method can be used. I also keep the blue mineral floater twistlocked with the chlorine floater and seems to work
